Let's start this adventure with your Rivo trainer. Discover what you will find inside the box.
2 3
Mounting the bike on the trainer
Find out how to assemble the trainer and how to mount your bike on it by selecting the right adapters depending on the type of bicycle you are using.
3 3
Rivo configuration
Here we are! Find out how to correctly configure your Rivo trainer to your home WiFi, how to activate Zwift Click in the Zwift app, and how to replace the Zwift Cog with a standard cassette.
